Source for 12V switched power for an Autometer oil temp gauge?
I am getting my oil temp gauge in FINALLY and I need a source of 12V switched power. Where have "all ya 'all" gone for this? I was thinking the 12V switched power socket that the MAF power wires is going to. Would there be any problem using this?
IPSC
IPSC
You need to make sure that it is clean, exactly 12v power or it will not read correctly. I recommend coming straight of the battery for power and finding a good clean gounding point for negative lead.
Originally Posted by V2Rocket_aka944
Where is it mounted? A-pillar or center console?
If it's on the console you could probably jump some power off the cigarette lighter or something.
Originally Posted by xsboost90
i tied the light for my boost gauge into a 12 wire under the center console that was not being used for a switch i dont have.
IPSC
Are you running the LR A-pillar gauge pod? How is it in terms of fitment? I am planning on getting it, but only if I don't need to go about all that modification after purchasing it in the first place.
IPSC
