Running without balance shafts
Anyone running without balance shafts? I have know a few people that did and the just plugged of the oil passages and capped off the balace shaft ports.
I was reading about that and they mentioned that parts of it have to be welded closed, which then means there's no going back. It's also supposed to create a good bit of vibration that can/has made bolts come loose on engine peices.
Originally Posted by V2Rocket_aka944
MPD47 has done it on one of his 951s, seemingly without consequence.
Although I agree with you, a few guys run cars without them and they are fine as far as I know. FWIW, that's not far.
![typing](https://rennlist.com/forums/graemlins/yltype.gif)
Under the Radar
Yeah, it's really not worth the two horsepower and ? lbs you save.
Do an AC delete if you want to save weight and reduce a load driven by the engine. I'm assuming your AC doesn't work, like most 944s. You also get the benefit of added cooling, by taking out the condensor in front of the radiator.
Geaux Tigers!
Search the 951 board. There's some pretty cool ways to delete the balance shafts. I'll dig up a couple of pics of a way a local guy has done to his turbo race car. First try was by cutting the balance shaft but then he decided to machine some out of Aluminum for added weight savings.
![](http://forums.rennlist.com/upload/balance_shaft_heavy_delete_blank_copy1.jpg)
![](http://forums.rennlist.com/upload/balance_shaft_wheavy_and_light_delete_blank_copy1.jpg)
![](http://forums.rennlist.com/upload/balannce_shaft_delete_blanks_copy1.jpg)
Those are some neat peices. I am already a/c less, no more backseat, pop up headlights manual sunroof etc. I bet a good balance job on the crank rods pistons would help.
Rainman
Those custom jobs are pretty spiffy...
I'm quite aware that Mike takes his cars apart every other day, twice on Thursdays just to make sure everything is still lighter than it should be. However, on his old build thread (Can I NA my turbo?) I asked him this very question and he along with several others replied that removing the balance shafts is fine for the motor. They said it doesn't significantly change the amount of vibrations coming from the engine, especially when at elevated RPMs.
Set to Full-Auto
The only real danger I have heard of is possibly breaking the oil pick-up tube due to added vibration.
I do not have any evidence supporting this, just throwing it out there.
I am not intrested in the performance gains, as much as the fact that it would be fun to do the work. I just love working on cars and seeing the end results.
Guys, I have ALWAYS run balance shafts on my 951's. The NA motor does not have them, but I will be inspecting the oil pickup to make sure there are no cracking issues. That, from what I understand, is your main concern.
I have read/heard comments about bolts for the A/C backing out, and oil pan (if mistorqued), but have no first hand knowledge on this as my engine isnt even running yet (nor does it have A/C)
Rather than welding the wholes shut and running the risk of deforming due to heat couldn't you just tap the passage and seal it with loctite and a bolt. I guess since I have a junk block I hace four chances to figure out how to plug one of the passages!
