One more time... I know...I know...
Ok so I have found a wheel that I would like to buy.
I have already bought my tires, they are 225/40/18 front and 285/30/18 rear.
The rims are 18x8 front with a 45mm offset.
Rears are 18x11 with a 52mm offset.
I will have them on a 1986 944 turbo. I first want to make sure they will fit.
2nd would like to know what would be the right spacer to use so I will have ZERO issues.
Thanks again Rennlist for your help
-Justin-
-Justin-
yes they will fit- you should know this! I have 295's on my 86. Not sure the exact equation but w/ 20mm or so spacers you should fit great depending on how far out you want the wheel to sit. I run 15mm spacers in the rear to fit my 45mm rears- and 25mm spacers up front.
