The H4 Lighting Roundup (or, how to brighten your lights!)
Old 06-19-2007, 12:20 AM
  #46
Wipeout
Not Special
Wipeout's Avatar
Submissions! That's what I was missing.
Old 06-19-2007, 12:56 PM
  #47
dnwong
dnwong's Avatar
Originally Posted by Ninefofo
Low on project cash and confronted with loads of wiring issues, I was going to build my own H4 wiring harness but a Jeep friend of mine turned me on to this place: http://www.4crawler.com/4x4/CheapTri...l#HarnessTypes You can pick up a harness for $45. Mine just came in on Saturday. Item came two days after paypal cleared. Other than the bright yellow sheathing it came in, it is solid. I will cover the yellow with some black friction tape. I plan on getting one for the Jeep too .
Michael, Which cable set did you get. Is the 944 a switched ground or switched output system?
Old 06-19-2007, 03:16 PM
  #48
UncleMaz
UncleMaz's Avatar
I believe our car is switched output. He wasn't sure, so I went with the switched ground. He shows an easy fix to reverse it if it is not correct http://www.4crawler.com/4x4/CheapTri...s.shtml#SGtoSP. One other thing I noticed, is that the wires are not soldered in like Rennbay's kit. I managed to pull out a wire in my feeding fiasco and have decided to solder the connectors. I got started yesterday, but did not finish it along with other wiring I have got going on. I will try to get it done this week before my Summer family trip.
Old 06-19-2007, 04:01 PM
  #49
dnwong
dnwong's Avatar
Sounds good with me. I don't mind going over and resoldering everything to save 90 bucks.
Old 07-05-2009, 01:37 AM
  #50
Vonov
Vonov's Avatar
Location: Nashville///'84 944NA, Virtual Luftwaffe pilot, Fighter Ace online
Darren...I hope you don't mind, but this posting was so good, and I was bugged by the way your original pics showed up so dark (for whatever reason). I adjusted the brightness and contrast in Photoshop, and the difference between the different light setups is even more striking...by your leave, sir, if you please...first, no lights...
Old 07-05-2009, 01:41 AM
  #51
Vonov
Vonov's Avatar
Then, the DOT-Legal Vision plus, high and low beams...I have to say, although the Vision Plus are some of the best DOT-legal lights I've seen, they still scatter too much for my taste.
Old 07-05-2009, 01:44 AM
  #52
Vonov
Vonov's Avatar
Then, with e-codes, low and high...I have a set of e-codes on my 92 Jetta (got the round headlight grille just to switch to e-code) and I will NEVER go back to DOT lighting...the sharper cutoff of the e-code makes use of the higher-wattage lamps possible, a MUST in deer country.
Old 07-05-2009, 01:46 AM
  #53
Vonov
Vonov's Avatar
Then with the e-code yellow...(I might have to try a set of these)
Old 07-05-2009, 01:49 AM
  #54
Vonov
Vonov's Avatar
And finally, with the e-code Xenons...(I think you might have been parked in a slightly different spot for these shots; the beam appears to be striking a tad high...still great output)
Old 07-05-2009, 10:54 AM
  #55
Wipeout
Not Special
Wipeout's Avatar
Yep, little dark in some of the photos because it wasn't 1030 at night in summertime so there was still a little light out there. And you're right, the xenon ones were in a slightly different spot because I took those almost a year later. One of my yellow bulbs burnt out, so I tried out the xenons.
Old 07-05-2009, 01:42 PM
  #56
Vonov
Vonov's Avatar
I know you did a bunch of work putting that post together, changing bulbs and so on...thanks again!
Old 12-14-2010, 11:11 PM
  #57
carbogecko
carbogecko's Avatar
Location: san diego ca. '86 944T metallic grey ps3 name carbon_gecko
great info i wish i had seen it prior to my current setup would of saved me some money i am sure. i use the 7" H6024 6014 H4 EURO CONVERSION DIAMOND CUT HEADLIGHT and they work amazing. since i commute through moutains daily i like to have my fog lights ready just in case the weather gets worse so i use the euro spec fog lenses and they work well
Old 12-15-2010, 11:28 AM
  #58
86 951 Driver
86 951 Driver's Avatar
Where did you get your lenses from? Are they the ebay ones? They look awfully bluish? Do they have a good pattern?
What did you do with your driving lights?
Old 12-15-2010, 11:56 AM
  #59
86 951 Driver
Do you have to just swap this stuff in or would I have for sure have to realign the headlights?
Old 03-29-2011, 04:34 AM
  #60
fasterfaster
fasterfaster's Avatar
Thought I'd add a resource to this thread. I used this guys kit in my old 4Runner/off-roader. Great tech info and lots of hard to get lighting products/electrical parts, e.g. Cibie lenses and Narva bulbs.
http://www.danielsternlighting.com/p.../products.html
Quick Reply: The H4 Lighting Roundup (or, how to brighten your lights!)
