8.5" rim with a 45mm offset - How wide
a tire should i be able to fit?
The pilot sports I had on the 8.5 boxster crabs rubbed the left wheel well.
I would be putting the 255 victoracer 700s on whatever wheel i get.
Originally Posted by V2Rocket_aka944
275s would probably fit pretty nicely ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
I have the tires. they rears are 255s. I dont want them to rub the left fender. does anyone know if a 8.5" rim with a 45mm offset will "probably"/"probably not" rub?
is your car early or late offset? If you have early offset, then the 45mm wheel will sit in and you may even need a 6mm spacer to make it come out- if you have late offset they will prob be sticking out the wheel well since you need 52-55 mm offset.
I also have run 255/50/16 Hoosiers on 8 F and 9 R D-90 with 52 offset with no rubbing. Again I have -2.5 to -3.0 camber on the track only car.
Before using R-compound, I used 255/17" Kumho MX on OE Cup II wheels with 55 off-set and no issues. I think that the off-set was less than what I have now becasue the car was driven to the track. The ride height was stock US at that time.
I hope this helps.
it is for my 88 turbo. the wheels are ROH, I called the distributor in NY and he told me they are 17" 8.5 wide with a 45mm offset.
i think 45 is not enough, and i need 50 to 55 on a 8.5 rim, hence my posting this thread.
perhaps he is off on his number.
is it agreed that if i am using 255s which give me the same 25" ride height that i need more than 45mm offset?
here is his ebay ad
http://cgi.ebay.com/ebaymotors/17-WH...98304581QQrdZ1
here is his ebay ad
For an 8.5" wheel that should be plenty of offset. My BBS wheels are 10" wide with only 47mm offset and I run 275/40 RA-1s without rubbing. Lot of camber, but still.
Then why did the 8.5 ??mm offset boxster crab wth 255 pilot sports rub on the left side so that i had to grind the lip (the stolen S2, not this car)?
Anyone know the offsets of the mille miglia cup rims? I think i have 17x9 on the rear. may be 8.5. with 255 pilot sports on the turbo and no rub.
I don't know Tom. Something was wrong with your car maybe?
Boxster 8.5" wheels are ET50. I know they work perfectly on the back of my fathers 951S with 255/40 ContiSportContact3's. Fit same as 17x9 ET55 wheels that lots of others use.
