Someone give me the confidence for a reseal and belt job
#31
Wax On, Wax Off
and rollers, you're taking them off anyway, so might as well replace them. seals are under some of the rollers. Honestly, it's preventative maintinance to do seals. they'll leak eventually, while you're in there, replace them so you don't need to worry about it.
#32
Wax On, Wax Off
Originally Posted by Clowd
Nice pictures man, that will definitely help me out.
I have another question for you guys...
the car has been sitting for about a year now ( I know, I know...) and I kind of want to drive it home (it's about a mile or two away) so I don't have to drive anywhere to work on it. The timing belt isn't bad or anything, it has about 20k on it, I'm actually only changing it because I'm going to be doing the seals. Is it risky, do you think, to drive it the couple miles home?
#33
Originally Posted by Mike C.
BTW, what year is your car? It has an updated water pump which is good and the wp pulley looks very new - any history on when this pump was installed? I'll bet not too long ago. It does look like oil has made its way in there.... definitely time for seals...
#36
If you will allow me to give this a different perspective. If you are able to set aside about 600 bucks before doing the work, then why NOT do it youself? For about that much you can send the head w/ bent valves, as a core, to a couple of vendors and replace it yourself. If you F it up agian you'll be a damned guru. lol
Seriously, other than the failure cost, and tool costs, the experience is invaluable. You only live once.
#38
