Is it ok to lift car at the transaxle?
you have to be careful where you put the jack- should be a wide jack and should be right under the fat part of the case- it pins the rubber mount between the case and the upper brace-have never had a problem and my mounts still look fine- i only do this when i need just the rear wheels up to place stands though, i dont leave it on there long. Ideally you would only want to use jack points though.
Hey Man
I do it all the time to place jackstands. I use the point where the TA attaches to the torque tube and a wider cradle on the jack. I've done this for over 3 years with no problems yet.
Location: Albany, CA: celebrating 100 years of independence from Berkeley, CA
Originally Posted by chrly924s
It HANGS by two skinny bolts that go thru the rubber mount. Your just asking for trouble.
It looks like the easiest place to lift the car quickly, so I tried it. It seemed to work fine. The tranaxle does move up a little before the car starts to lift, but I don't think it's a big deal.
Originally Posted by xsboost90
when jacking the trans up, it does not place any pressure on those bolts- it pins the cage for the mount between the case and the brace on the frame.
Yep, Im pretty sure the rubber mount collapses enough, so that you have solid contact between the case/alum mounting block and the mount body.
Regardless, I recall those two bolts are M8 (8mm), so they have a cross sectional area of 0.078 sq. in. each. If the back half of the car weighs 1500 pounds, that is approx 9600 psi shear stress on each of those bolts (if they are loose). Proof strength for a SAE Grade 5 (very similar to DIN 8.8) is approx 70,000 psi. For a static loading, they will not bend or break.
The only concern with this jacking method, would be possibly damaging a very old/brittle rubber mount.
But with that said, I have jacked the rear of 944s using a 2x4 as a jack pad under the trans for years.
