starter issues...
Lifetime Member
Lifetime Member
Went to start the 944 yesterday and all that occured was a grinding sound, and the whine of the starter (heard since the car wasn't turning over). Fortunately, I was in a parking lot with a large slope, so I got going and popped the clutch and drove home. In my driveway, I turned off then immediately restarted the car and it started up. The starter has been for the last several months, grinding a bit after the engine turns over. I checked the starter and it's secure in there, so I pulled it out and the teeth look a bit polished but I'm not sure how a new one would look (ie, how deep the grooves should be, etc). The teeth of the flywheel look OK from the few I can see in the opening. What's the easiest way to turn the flywheel while looking through that opening and working solo? I'd like to check the rest of the teeth.
Thanks,
Matt
Thanks,
Matt
Matt,
I have no idea if your flywheel is OK, but I thought I'd let you know that Kevin (FSAracer) has a used starter for sale. Check out his thread.
If you have a large breaker bar and deep socket set, you can turn the engine over using the crankshaft bolt and it would turn the flywheel so you could inspect all the teeth. Good luck!
Lifetime Member
Lifetime Member
Originally Posted by Maciek
Matt,
Lifetime Member
Lifetime Member
Originally Posted by V2Rocket_aka944
Be sure to pull the fuel lines and spark plugs.
I got a new starter and the teeth are indeed hosed on the old one. Night and day difference. Installed the new one and it works to perfection.
Another problem bites the dust.
