Help me ID my front sway bar...
03-07-2007, 12:15 AM
Not SpecialRennlist Member
Bushing on right side is busted, so I need a new one (well two, doesn't make much sense to replace one rubber bit and not the other!). Trouble is, I can't tell what size the sway is and I'm not entirely sure how to read my caliper. Here is a picture:
03-07-2007, 12:17 AM
I am guessing you have a 21.5 mm bar.
Its inbetween what it 'should' be. so its either 21.5mm or 23mm.
03-07-2007, 12:19 AM
HAHA, great. Does the fact that I have an 85/1 change matters much? You guys are reading the "out" number, right?
The measurement shown on the caliper is a little over 23mm.
You use the "out" line when you are measuring the outside diameter of something (such as your sway bar).
03-07-2007, 12:20 AM
I will go and re-measure now that I know that and attempt to get a reading at the car.
03-07-2007, 12:21 AM
Well its kinda hard to measure lower than it actually is lol , so i would think it is a 21.5.
03-07-2007, 12:22 AM
Camaro, I did bring it into the house and probably jostled it a bit. I'd rather "cut twice and measure once," know what I mean?
03-07-2007, 12:23 AM
Can you get a part number off of one of the bushings?
Yea i know it bro. Keep your fingers crossed its a 23.5!
03-07-2007, 12:25 AM
Why should I hope for 23.5?
I probably could check for the part number, yes. I will have to check on that.
03-07-2007, 12:31 AM
Umm its bigger than a 21.5, less roll.
03-07-2007, 12:36 AM
Heh, I thought there was something more to it.
03-07-2007, 12:58 AM
Nissan RulezRennlist Member
from the reading I say its a 23.5mm most definatly. go double check just to be shure.
