TT rebuild bushings
Old 02-26-2007, 06:21 PM
  #31
Mike B
Done With Sidepatch
Mike B's Avatar
I'm in for one set.
Old 02-26-2007, 06:24 PM
  #32
500
500's Avatar
Originally Posted by byrdman454
Jon,
I PMed you about needing a set for my 928.
I do have a question for you guys about bearings. I am having a hard time finding suitable replacements. My 928 came with 6006 ZZ C5 HT51. Is this the same thing you guys have? The ZZ is double shielded which is not a problem. One problem is the the C5 tolerance has not been manufactured in forever, but I have been told that I can use a C3 or C4. I guess the biggest problem is finding this bearing with the high temp grease HT51. Are you guys having the same problem? If not, where are you guys getting these things.
I am rebuilding my TT too (although I have already made my bushings...)
Anyway, a decent source for bearings is MSC direct (link ) I purchased my bearings from here and they are marked as:
6006-2Z C3 GJN and are made by SKF
6006 = basic bearing number
2Z = double shielded, as you stated
C3 = clearance (and I agree that C3 is fine for this application)
GJN = "Grease with polyurea thickener of consistency 2 to the NLGI Scale for temperature range –30 to +150 °C (normal filling grade)" (Quoted text is directly from SKF.com).
This grease is a very similar formulation to that used in the HT51 spec which (again copied from the SKF site) is described as: "Grease with polyurea thickener of consistency 2 to the NLGI Scale for temperature range –40 to +150 °C (normal fill grade)"
In other words, HT has the same max temperature, with a slightly lower minimum temperature, but most of us won't operate in that range, so I think that it should be ok.
This is the closest I could find. I originally has purchased some other bearings but was not happy when I realized the grease did not have the same temperature rating.
(Take all this with a grain of salt, I am not a bearing expert)
Old 02-26-2007, 06:42 PM
  #33
Jon Moeller
Jon Moeller's Avatar
Damn, it. I'm probably going to end up using these instead of the C4 units I just bought. The grease in the C4 units is rated to ~250F. That additional 50F seems like it would be worth it.
-Jon
Old 02-26-2007, 06:43 PM
  #34
Trucho-951
Trucho-951's Avatar
Jon, put me down for a set.
Old 02-26-2007, 07:52 PM
  #35
rkb58
rkb58's Avatar
I would like a set, also,
Thanks,
Robert
Old 02-26-2007, 08:29 PM
  #36
strandolph
strandolph's Avatar
One set for me as well.
--Steve
Old 02-27-2007, 10:40 AM
  #37
500
500's Avatar
Just another thought regarding the heat issue: Since my TT is obviously out of the car, I am having it powder coated, but instead of the original black, I am going for a bright silver finish to help reflect a bit of the radiant heat - may not make a huge difference, but can't hurt either. Since the TT is out of the car, and usually looks a little old and ugly, even a decent spray can job might be worth the effort?
Old 02-27-2007, 10:55 AM
  #38
Maciek
Maciek's Avatar
Jon,
Please add me for one set. Thanks!
Old 02-27-2007, 12:01 PM
  #39
EMBPilot
EMBPilot's Avatar
Allen,
the link in your post above does not link to 6006-2Z C3 GJN but it links to 6006 2ZJEM
two different bearings right?
Old 02-27-2007, 12:49 PM
  #40
500
500's Avatar
Unfortunately the MSC website does not allow that amount of specification, you actually have to call to confirm what they physically have (best to ask them to read the markings directly on the bearing to be sure)... Sorry, I had meant to mention that caution with the link, but omitted that in haste. Thank you for pointing that out.
MSC seems to have a lot of distribution warehouses and is BIG. There may be other vendors that are more convenient. As it was, I tried to find something up here in Canada, and not being an industrial customer made it very hard.
EDIT: Since I posted above, I checked the boxes my bearings came in, and they do have the JEM suffix, although, as mentioned, the bearings themselves are actually marked 6006 C3 GJN. I cannot find mention of JEM on the SKF site as a suffix (or prefix for that matter) but from a different source (some motorcycle page) someone stated that JEM meant high temperature grease... So MAYBE JEM is an old suffix? Anyway, the best is to call and confirm...
Old 03-01-2007, 10:37 AM
  #41
Jon Moeller
Update: There are now 14 944 sets remaining.
Gary Knox informed me that his '94 GTS has a larger diameter shaft (28 mm), so these bushings are not applicable to these cars. I do not know when this change was made, so please keep this in mind, if you're ordering for a 928.
-Jon
Old 03-01-2007, 10:44 AM
  #42
badmofofosho
I Bad
badmofofosho's Avatar
I'm in for a set Jon
Old 03-01-2007, 11:14 AM
  #43
John Veninger
John Veninger's Avatar
I'll take a set (3) for a 928.
Thanks!
Old 03-01-2007, 12:22 PM
  #44
944S2IFISH2
944S2IFISH2's Avatar
Could you please add me to the list for 1 set for a 944S2.
Thanks!
Old 03-07-2007, 11:52 PM
  #45
Jon Moeller
Default Update - Payment info
I just received the invoice from the machine shop. I'll be sending in the payment, tomorrow.
I'm not a big fan of tying up everyone's money for a month, but I'm less of a fan of tying up a significant amount of my own money for the same time frame. With that in mind, I'd like to start collecting the money for these.
The total price will be $15/bushing + $1 for the padded envelope + $7 for FedEx Ground shipping ($68 for 944's, $53 for the 928 guys). Shipping calculation was based on sending a 1 lb package to my old zip code in MN. I'm sorry, but I'd rather not calculate individual shipping cost for the 35+ sets of bushings that are currently going out.
Checks can be sent to:
Jon Moeller
394 Hamilton St.
Albany, NY 12210
If you want to do paypal, please include 3% to cover the damn fees. The total for PayPal is $70.04. PP username is JMoeller<at>nycap<dot>rr<dot>com.
Also, please make sure you send me your address electronically (e-mail or PM). This will make it much easier for me to get stuff shipped.
Thanks,
Jon
Quick Reply: TT rebuild bushings
