or not. Got my wheels fed-ex today and test fit them. The fronts fit perfect w/ a 25mm bolt on spacer. The rears are going to be tricky. The driver's side fits fine w/ a slip on 8mm spacer but the passenger side rubs the inner wheelwell w/ the same spacer. I called up Paragon-products and ordered some 15mm rear spacers w/ longer studs and they should work on both sides-ds is alittle less picky space wise. They look great and the tires are good enough to last me awhile- doubt i'll be spinning the 295 rear tires very much!!!
enjoy.
Dammit Dan, I'm so jealous. I want those wheels so bad but, I don't think there is anyway they'd fit on a late offset car. By the way I recieved the PS pump awhile ago, thanks again.
Dan,
Love the wheels! Now quit changing your car.....which necessitates changing the avatar! Radiologists are visual people..I can never tell who you are anymore!
