Lindsey Boost Enhancer
I just installed a Lindsey Boost Enhance and although I think i did it correctly there is a kink in the hose. Is this ok? Here are some pics.
Originally Posted by Keithr726
You need to trim down those hoses, they're holding it up too high. Look at the picture on the LR website to get an idea.
Originally Posted by Techno Duck
That kink will cause problems.
Try to route that longer line around the 2nd intake runner.
Does this help?
funny thing happened today. Marisa has pneumonia. no thats not the funny thing. I am a captive at the house so i cleaned the garage, put the stuff in back of the miata in front of the 951, put the phone dials on the NA, put the 968 rims on the S2, put the car cover in the hatch of the S2.
in order to do that i had to back the turbo out. when i pulled it in i didnt pull it all the way in. i left enough room to walk around the car from the front. so all i had to do was go out the door walk in back of the miata, which is possible now that the extra roofing materials are not ther, walk between the cars which is possible now that the jogging stroller is not in the middle, in front of the 951 and around to open the hood.
Originally Posted by jeeper31
What happened?
Originally Posted by chitown944
Um...what does the LBE do all by itself.
It holds pressure until a certain set point and then it allows pressure to flow freely to the waste gate. By doing so it speeds up your spool time and you make maximum boost.
