Odometer Question?
Odometer Question?
My odometer stopped working tonight. If I reset the trip odometer it still resets. Do I have a stripped gear or worse? I need to get this fixed asap.
Thanks, Richard
Thanks, Richard
I have an ODO with a brand new gear that works intermittently. I have taken the gauge cluster out, and it will work for a while, but eventually will stop. Not sure if it happens only after a reset or not. But it is annoying as hell.
Thanks, Richard
Thanks, Richard
Link to my original ad
Thanks guys, after talking to Travis at rennbay, I think it is my gear. I don't want my mileage to be off more than 100 miles so I will order a new gear and go from there.
Oh and I have never reset the mileage while rolling. ARGGHHHH!!!!!!!
I never rest my trip odo.
Ive fixed a broken gear once, and then when I went to reset while stopped, my odo just jammed up.
I noticed on the 2nd fix that there is so much play in the numbers and gears in my odometer it just jams rather easily. It has stayed spinning ever since the 2nd fix.
I paid for a gear and Travis was nice enough to return my money and told me I didn't need it in my early and explained how to fix it (thanks Travis, I just remembered that).
Can't be moving when you reset the odometer - so f'n annoying. What is the point of having a trip odometer that you can't reset while moving (I acutally like using the trip). I cracked that speedo case too many times. Everytime, probably pilot error, something else wouldn't work. My storage area looks like a clock shop filled with gauge parts. I got so tired of it, I tossed all of those wonky VDO gauges.
