sunroof need help
what year is your car? IF its 85.5 you have to put the key into the #1 position meaning the first click from totally off- then press the sunroof button and it will either go up, or the arms will retract out of the roof- Then you can unclip the front and push it up and pull back and itll slipp off of the air foil in the front.
You have to get it to the closed position, then put the ignition in position #1 and press down or up, can't remember, anyway only one direction will work at this point. You will see the arms completely retract, then you can unlatch the front and remove it.
A search would have also turned up a bunch of posts with the answer.
that isnt working though there are 3 little arms in the way and i dont want to push to hard it feels like is gonna break there has got to be an easier way can someone give me step by step
i unlatched the two pieces over the driver head and passenger head
and now is the sunroof supposed to be tilted up or down i put it down and it wouldnt budge do i have to unscrew something
chris
chris
3 arms??? Then sorry I'm out, I have no idea, can't help. There should only be 2
In any case, you might want to take a look at those.
https://rennlist.com/forums/showthre...remove+sunroof
Originally Posted by vwvortex123
how do u get the sunroof out i dont want to break something
if all fails, search SidVicious and go manual.
chris
chris
2) with the car off and the sunroof completely closed insert your key in the ignition.
3) move the key to the accessories position (DON'T TURN THE CAR ON)
4) Press your sunroof switch until the ARMs retract don't open your sunroof , what you want to do is keep it close and retract the arms so you can pull the sunroof out.
5) disconnect 2 front latches, sunroof should be free to remove.
There is not such thing like 3 arms, there is only 2 latches at the front and 2 arms at the end.
