Hatch de-fogger... WTF?
Wax On, Wax Off
Hokay... on the 924S, the hatch defogger is not working. I left it on for the entire 30 minute drive to work, and no dice... it eventually melted the snow (yes, I brushed it off...) that was left because the cabin was warm...
So, today, I decided I'd utilize the trusty multi-meter and see what was going on. I checked voltage across each wire, as well as across the circuit as a whole, and each one is fine... through the entire test, there was snow on the hatch, (a dusting) and it wasn't melting... I was pulling 14 V across it.
any ideas what the problem is? the 924S is my winter car right now, and I kinda need this to work... and I'm stumped.
Thanks!
Thanks!
I have the same issue on my '86 944. Contacts are firmly in place, but the defogger still doesn't work. The light comes on, and the driver's side heated mirror works (passenger's side doesn't work, but is there even one on the passenger side?).
I am stumped! What can I do about it?
But first I'd verify there is actual voltage at the connector, and that the ground (which on my car at least is thru the hatch strut) is intact.
Well, I just bought the car, but the previous owner has records showing that he just had the rear struts replaced. I see that they do have the correct electrical connectors on them. I will have to test the actual voltage.
Wax On, Wax Off
yeah... I sold the car...
HOWEVER, I did stumble across the problem when I was tracing an electrical issue that killed the clock, dome light, and stereo... the wiring for the defogger switch, at the switch, was crispy and burned. the insulation had melted off the wires. Good luck, hope this helps!
