Basic Brake Bleeding Question
Stupid question, I recently bleed the brakes on my neighbors car, used mitivac, all went well. Now I need to replace the driver side caliper as it has locked up, do I need to bleed all 4 again, or can I just do the driver side rear and make sure the fluid level stays full?
Thanks.
Thanks.
if you are fixing/replacing just 1 caliper then you can just unhook the line and plug it with something quickly and put it aside
change what you have to change, reinstall, and bleed the one side to get any air (if at all) out
i dont see a need to bleed all 4 again.
Originally Posted by Cosmatics951
Thanks. Along those lines, if a caliper with 210k miles on it, has finally locked up, should i just get a new one or try to rebuild it. I'm thinking just get a new or reman'd one.
really if you are going to purchase new calipers you are better of researching a serious upgrade to your brakes to save time and money.
I'm not an expert on braking systems, but it was a suggestion on another board. I had to rebuild my calipers twice this year, and it kept fluid from dripping out of the line. There is no need to cap it. You'll only lose fluid from the caliper, naturally, and a drop or two from the line. FWIW, this is based on me doing it twice, and it working well; not just an idea I had.
