special thanks to BlueDog944
BlueDog944 came over tonight and in 15 min had that clutch fork pin out and the bell housing off. What I could not do in 4 days, he did in 15 minutes. I was in shock and awe...
thanks!!! you and I
I owe you a beer
thanks!!! you and I
I owe you a beer
Originally Posted by Mike C.
Really? Is there a hole to do that or did he drill one?
I thought i could not get to it from there, but he, took the punch and 30 sec later its out.
That's interesting, the early bellhousing on my 83 had no hole, just a pocket from the inside. That shaft has been cursed at many times here. Mine came out easy probably because it's always been a dry California car with no road salts. You guys in the Midwest and back east are always breaking off bolts due to corrosion issues. Maybe that's the only good thing about living here! That was great of him to come over and help, that's what rennlist is all about.
awwwww, schucks
Really glad I could help. Sometimes all it takes is a fresh pair of eyes.
Yes, there's an access hole at the other end of the pin in the Bell housing. When the motor is in the car its not accessable. Using the long punch you can "pursuade" it from the inside. You just have to be careful of the stop pin that keeps the it from sliding in too far. A little spray of the "secret" oil and some taps on the punch and she broke free.
In all honesty, the clutch is not really a difficult job to do, its just time consuming. With the motor in the car there is so many related things you need to do first in order to get to it. That and there are two or three special tools you need, sockets mainly.
Originally Posted by xsboost90
just pulled the pin from mine the other week- just need an extension and a rubber mallet- POP* she's out. Now lets see if i can put it back together the right way....
