late engine in early car?
what would i need to make this work? I have an 83 motor, that I'm tearing down and I'm going to put high comp pistons in it. But I wonder if i can run the 84 DME/AFM or should i used an late DME/AFM?
Also, I hear the cam profile is different on the late cars, how hard is it to swap cams?
Originally Posted by Mike Markota
put early fuel rail on and use your early dme /afm or use late rail with late DME/AFM
I dont think there is an easy way to mount a late rail on an early car, the fuel lines will have to be moved, which would be a PITA.
Originally Posted by Legoland951
The high compression engine has a different DME than the rest of the other years. The part number ends with a 5 instead of 1 or 2 of the early DMEs.
Originally Posted by tod84944
Just find a dme from a 88, and that will work.
The reason I'm asking is i want to take every advantage of the pistons.
Originally Posted by M758
Ross,
You can do alot of mixing & matching. I ran a complete 87 924S motor in my 84 chassis. Now it uses the 84 block with 87 head & injection. I even ran an 88 block in there for a bit too.
Originally Posted by mjaffe
Joe, I had heard through a local guy that 88 DME retards timing at high operating temperatures. Have you heard/do you know that? If it does, I imagine that would be less desirable for a track car. Any thoughts?
Dylan Scott keeps saying that. I have no data to confirm/deny.
My car runs with a chipped 87 DME. I ran for a few sessions with a stock 88 DME when I ran the 88 block. Seat of the pants and lap times seemed show a tiny bit more hp with chipped 87 DME so I just used that.
My 87 DME does not seem to have that issue.
