Foam under the shift boot?
Old 10-26-2006, 12:57 PM
  #31
tifosiman
tifosiman's Avatar
I think someone should write up a DIY procedure on this and submit it to the 944 DIY section.
Old 02-28-2007, 07:10 PM
  #32
UncleMaz
UncleMaz's Avatar
Originally Posted by 944-LT1
Not sure if this helps temporarily.... but i bought one of those cheapy foam sponges shaped like a big peanut for washing cars, slit a small hole in it, and stuffed it down there. Worked nicely until I could take the TT out for replacement (main reason was to replace clutch discs).
Finally, I was inspired to install my peanut sponge I read about a few months ago after reading this thread. I installed the peanut sponge last night. Shifts tighter, less rattle on an aftermarket ****, cut down, rebuilt shifter. I am not sure how long it will last, but an excellent cheap fix for a neggling issue. Thanks 944-LT1. Thanks Rennlist.
Old 02-28-2007, 07:31 PM
  #33
V2Rocket
Rainman
V2Rocket's Avatar
I took out the nasty old one and made my own with a bandsaw
Quick Reply: Foam under the shift boot?
