Drain gas tank
Hey Man
Originally Posted by pkt12113
Bad gas doesn't burn for ****. The hydrocarbon chains have changed into something that's isn't flamiable.
Wow. Gas can go bad in 60 days. My car can't ****in run at all cause the gas is so bad.
Oh well. I might see if I can burn it off. To bad then it goes bad it doesn't turn into Napalm.
Hey Man
I don't know. I work at autozone and was tlaking to the guys there and we looked on the back of several of the things of fuel stabilizer and that's what they say. I know several people that have cars and motorcycles that fuel goes bad in like the 3 months they sit over the winter.
Maybe I'll ask my anyalitical chem teacher tomorrow and we can go through it and see what contributes to the change.
Lazer Beam Shooter
What's the best way to do this? I was trying to syphon it out, using my shop vac to start it but the tubing isn't even getting to the gas.
I had a tank go bad.
then drain out rest ?
Ditoo ^ ^ my lawnmoewer had gas which was at least 6-9 months old ?
no problems
Not to say you don't have a bad tank of gas but...... From time to time I start up my '84 944 to move it around the garage and the gas that is in that car was pumped in June of 2005 with no additives added.
If you are convinced your gas is bad, just drain 5 gallons at a time and give it to your friends for their mowers and such, that's what I did last time I had to drain a full tank. I put a fule safe plastic valve on the end of a hose that I attached to the fuel line and was able to turn the flow on and off to fill up different gas cans. And by the way, the last tank I drained was a 72 super beetle that had 12 year old gas in it, that gas ran great in my mower and weedwacker and none of my neighbors complained about the free gas I gave them.
Tom
Tom
Wow. Gas can go bad in 60 days. My car can't f*in run at all cause the gas is so bad
The gas in my Honda CRX sat in the car (outside) for several years until I sold it (I wasn't trying to sell it... someone asked about it, we agreed on a price). Jump started the battery and it fired right up.
Hmm. Then what's the big deal about gas going bad over the winter? I've had a tank go bad on my bike cause it sat all winter. That's a hell of a lot easier to drain. Well I am going to drain it tomorrow between classes.
Gas stabilizer is a good idea for storage, and gasoline does "go bad' - eventually - it'll gum things up if it goes bad enough, but fuel injector cleaner or carb cleaner generally clears it up when/if it gets that bad. However, I wouldn't expect it to get that bad sitting in a gas tank for 3-6 months, and it's still flammable at that point.
The gas in my lawn tractor and my 944 both sit in the tank for six months before the next lawn cutting/driving season, never had any problems with "old" gas (I was going to add fuel stabilizer to my 944 tank, just forgot last year)
But if I was worried about gas going bad... 20 gallons x $2.20 = $44, fuel stabilizer is... $8? or thereabouts?
You can always drain out half of the old gas, add in 10 gallons of new gas into your car and drive it... fill with new gas next fillup, let that go halfway down, then add the remainder of the old gas...
