Water pump while doing timing belt?
Went to the local shop today to get an appt to do the timing belts and a couple other things, and the guy was wondering if the car has had the water pump replaced yet. He didn't give me a quote on the belts because he's not sure if the rollers need replacing and whatnot, but also because he hadn't done a timing belt job without replacing the water pump at the same time.
Anyway, the car has ~83k mi on it and from what I can tell in the records is still using the original water pump (I've emailed the PO to check). Should I get a new water pump while they're in there or do they usually last a while?
The car has been running rather hot recently, but I'm hoping that a coolant flush will get rid of that problem - from the records it looks like the last time that was done was in 1990.
Could this be a sign that the pump may be going out? Or does the pump just go kaput and not slowly die?
TIA for any info.
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
TIA for any info.
Replace it.
No brainer. The majority of the labor is in the belts and the other stuff. Changing the water pump at that time only adds the expense of the part and maybe a minute amount of labor cost. It would be unfortunate to do the belts now, then have to do the job again later if the pump starts leaking (or worst-case, locks up).
Originally Posted by Tom R.
my wrench does not use two things remanufactured, one is water pumps.
Originally Posted by tifosiman
OK, you know I have to ask.............................................................what's the other thing? Starters?
the chances of getting a bad one are too high and he doesnt feel like doing the work twice, the second time on his dime so he says new or go somewhere else.
i am pretty sure it is starters. know it isnt alternators so yep starters.
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
1 Post
It's certainly good to replace the water pump, but don't get fooled that it's almost no extra work, and the shop most likely will charge you extra. One needs to remove the rear belt cover, and all rollers first. And some of the rollers are quite hard to remove. And then why not to change all front seals?
In a nutshell, replacing the belts is a small job in my opinion, but the other stuff mentioned above doubles (or more) the amount of labour.
But if you have money - do it.
Bill...I'm finding out there a few cars out there that still have the old (not updated) water pump. And that includes an 86 951 like yours. You might want to make sure the shop knows to replace with the updated version. Just a thought...bruce
