No automatic reset of turn signals with Momo steering wheels (?)
Originally Posted by J Silverman
If you cant get the momo hub working, a mk1 VW rabbit hub should work. Mine is a sparco, and the turn signal cancel looks exactly like the part on the OEM wheel.
I have a sparco rabbit hub in my car(88 924s). I had the same problem as the original poster where the turn signal cancel wouldnt work. It didnt look anything close to the part on the OEM wheel i removed so I brought it back to my friend who sold it to me and we started going through some old stock they had and we came across the rabbit hub. Sure enough it fit and works just fine! I can only assume that a momo rabbit hub would work as well since the steering column is a VW part. Just looka t it before you buy.
this is an old thread but for the next person that looks for the answer.... the answer is the turn signal cancellation ring needs to be moved from the bottom of the factory steering wheel to Momo hub. Its held on with three screws and has a tab sticking out of it that cancels the turn signal.
