Got my new fuel lines from rennbay
THERE BLACK!!
the blue is gone. I didnt mind it, but just thought id give a heads up to whoever is planning to get some. Thanks travis!
ill post updates when i get started on it.
-Seb
-Seb
I got the blue ones... . They are not as light as they look in the picture. I used to not like them because of that but now that i see them in person they should look nice under the engine .
(they go on top of the engine. )
6 hours and 12 iced teas later, my fuel lines are in!
pix coming soon.
1 question though; the one fuel line that goes from the dampener to the wheel well is very close, almost touching, the intake manifold. I know the manifold gets very hot and was wondering if that is ok? or should I try to move / fix it?
thanks alot travis!
-Seb
pix coming soon.
thanks alot travis!
-Seb
Tough to get the compression fittings off at the hardlines? Going to do mine tomorrow i think..should be easy with the top end of my motor already off.. .
the compression fittings took me about 30 min before I said screw it and got out the dremel and tossed the hacksaw. its not as tough as you would think. If you have any questions feel free to ask. I have to say, it would have only taken 2 hours if I didnt have to;
1. Get a pipe cutter from home depot
2. calling to annoy Travis every half hour
3. Have 2 of the "easy to remove" bolts get stuck on me.
still wondering about the intake manifold question (see my previous post)
PICTURES!
PICTURES!
thx
-Seb
Seb, how did you cut the fittings with the Dremel, just across the fitting length wise or side to side? Just curious. Going to be doing it myself tomorrow.
What did you need the pipe cutter for?
I was going to use the pipe cutter for cutting lower, behind the wheel well, but when I asked Travis about it, he said it was a bad idea, due to the lack of a proper fitting.
I cut length-wise with the dremel, that way it will just peel off.
