No start, no sell...
#33
I've got an extra AFM we can put in. I'm out of town at the moment, but will be back next week. Call me at 785-865-3435 next Monday and lets see if we can't beat this thing.
Regards,
Regards,
#40
UPDATE: After how long, I am afraid to look, we applied some starting fluid to the 944 and it started and ran.
Narrows this down to a fuel injection issue I believe -
Earlier tests show the fuel pump works, fuel pumps. Maybe something to trip the injectors -
Maybe the suspect speed or reference sensor??? Tach works, ignition obviously works -
Time to dig the manual out again.
Feeling motivated by Jim Cooper, feel the desire to get the 944 going again ....
Could it be - the passion is returning?
I hope!
Any ideas or suggestions andor encouragement welcomed with wide open arms.
I hope!
#41
After you get it started, does it run like normal? Maybe the basics of fuel and spark are OK. There is a temp sensor at the front of the head on the intake side. The DME sets the mixture richer for a cold engine based on this device. I tested mine in a pan of water on the stove. The resistance changes with temperature. A new one is about $25.
#44
No massive air leaks - replaced things, like the J-hose, with new parts a while back.
Also, took the DME relay out and checked it, it is also new ...
Thanks!!!!!
Thanks!!!!!
