Central door lock question
Previous owner had disabled the factory alarm system...had the unit in the glove box. my central locking system does not work. So my question is: With the alarm disabled, does it disable my locking system also? Or do I have a switch, etc. problem.
Fuses are OK by the way
87 944S
87 944S
87 944S
87 944S
That's it....it's was just taken out. It's not mounted or installed..just a place to keep off the floor until I drove the car home. I'm a newbie Porsche owner if you hav'ent guessed by now. I'm talking about the alarm module
I received my central lock module....easy to install, just plug and clamp. My rear hatch will release but I hear nothing from the door locks. I'm supposed to get a light from the the button when engaged right ? I have the ignition switch on # 2 while pushing the button. Is the button (switch) removable like the window switches. I followed Clarks Garage for the switch re-furb and they work like brand new.
When you lock the doors with the key, do you ear them lock, especialy the opposite side. Both doors should lock at the same time and the light in the ***** should light up or flash.
Actually the console switch, if that's the one your talking about is pretty useless, dont even bother with it. If I understand correctly, it is only used in the event that a little lady feels treatened, she can press the little button and she'll be safe because the doors will lock
Once they're locked that way, the only way to get out is to manually pull on the lock **** and that's when they break ask me how I know, so dont use it. The switch does not arm the alarm system, it only locks the doors.
To arm the system, you have to be outside of the car and lock it with the key. This should lock both doors, and arm the alarm system.
If the module was removed, you might also be missing one or two relays that compose the system. I cant remember the location. Have you checked those.
The button on the console locks and unlocks the doors. If your doors lock and unlock with the key lock in the door handle the the micro switches in the handles are fine. the other thing that breaks on the locking system is a plastic arm inside each door. When my CLS went south it was a broken arm. Easy fix and relatively inexpensive as I recall.
Not on mine !! If I press it locks the doors and if I press again it does nothing, or to be more exact, I ear something like it's trying to lock again. It's a single throw switch that I have with a small red light in it, right?
I was hoping to get a remote keyless entry for it. I've read a couple threads that made that possible. The doors lock and unlock fine using the keys. Not knowing what caused the problem in the first place makes it much harder to troubleshoot. It was like this when I bought it.
Mine was the same so that's why I know a little about this. I found out later that the PO had disabled it and he gave me the missing parts. One control module and 2 relays. Plugg everything in and voila.
Your problem sounds like the small micro switch in the key lock themselves aren't working. If you lock one side, does the other also lock?
