No more holes!
No more holes!
Need to fix eight 1/4" holes on my bumper and on each side of my license plate. What should I steer away from (filler vs TIG weld) when I take it someplace? Looking for a reputable place near Jacksonville, FL too.
i used a mig welder and filled the holes in on each side of the plate. Then grinded everything smooth. You may have to loose your options sticker though. If you fiberglass/bondo etc it up, it will eventually shrink up and you will at the very least have a ring where the hole used to be. The rear bumper will have to be tig welded up- aluminum- i think im just going to find another bumper and paint it though.
Cleveland Rocks
ive had two of these bumpers welded- my old neighbor was a welder- and it worked out great. Thing is to use some etch primer on the welds though before you smooth it out the rest of the way, they have a tendancy to oxidize under the paint etc if you leave them bare.
Nissan Rulez
The rear bumper will have to be tig welded up- aluminum.
