Little K26-8 and K27-6 comparo...
Old 08-20-2006, 04:32 PM
docwyte
docwyte's Avatar
"I have a gaping *******"
Wow, I don't think I'd be broadcasting that on an open forum....
hehehe....
Old 08-20-2006, 05:14 PM
Tabor
Tabor's Avatar
Originally Posted by theedge
The stock boost control is so-so at best. MBCs often let air leak a bit, since they are still spring valves. Add in the fact that the stock wastegate is also pretty so-so...
Fair enough. But with a GOOD non-bleed MBC, they stock wastegate will see ZERO boost until your max boost setting is reached at the MBC. One such controller that I have never heard a bad word spoken about is this one. How much do electronic boost controllers cost? This thing is $47.
Old 08-20-2006, 10:46 PM
docwyte
docwyte's Avatar
All I can say is my greddy ebc is worth every bit of the $200 I spent for it.
Old 08-20-2006, 11:36 PM
Lorax
The Impaler
Lorax's Avatar
Someone should inform us as to when the 26-8 is really supposed to hit full boost, because mine comes around 4k also.
Old 08-20-2006, 11:39 PM
docwyte
docwyte's Avatar
3000 rpm.
Old 08-20-2006, 11:47 PM
Lorax
The Impaler
Lorax's Avatar
Even with no boost controller? Should I start hunting for vac leaks again?
Old 08-21-2006, 12:42 AM
Tabor
Tabor's Avatar
So, if your problem was a boost leak, and it was delaying full boost by 1000 RPM, that would be a BIG leak. You should be able to hear it from in the cabin, and there should be a bunch of oil where ever the leak is.
I bet your wastegate actuator is tired, and that has more to do with it. Buy the boost controler that I linked to and see if it fixes the problem.
Old 08-21-2006, 12:55 PM
testarossa_td
testarossa_td's Avatar
Thanks for the real world test info.
Quick Reply: Little K26-8 and K27-6 comparo...
