RA1 hot pressure on 944/951
Old 07-28-2006 | 11:11 PM
shiners780's Avatar
shiners780
Default RA1 hot pressure on 944/951
For you 944/951 track guys running RA1s:
What hot pressures do you shoot for to obtain maximum grip. I'm getting a set mounted on Monday, my first set of RA1s after years of using MPSCs.
Is the target hot pressure staggered front to rear, or the same at all four corners? Michelin recently began suggesting using a staggered setup; with a two pound variance front to rear (fronts 2+ higher than rear.) This has actually worked out quite well.
What works best for RA1s?
TIA
Old 07-28-2006 | 11:17 PM
Riff's Avatar
Riff
I try to get 40lbs hot on all 4. I run 245's all around.
HTH
Old 07-28-2006 | 11:40 PM
OriginalSterm's Avatar
OriginalSterm
not Pcar related, but RA1 related...
in the Talon we run the same size tires all around and shoot for 40# hot also.
Old 07-29-2006 | 12:18 AM
josephsc's Avatar
josephsc
From: Albany, CA: celebrating 100 years of independence from Berkeley, CA
I just recently started to do lots of track events. The recommendation I got from a couple of different places is also to shoot for 40# hot. I'm running 225/50/15 RA1 on all four corners.
Old 07-29-2006 | 12:22 AM
aeshultz's Avatar
aeshultz
Same here - 40 hot, 225s all around on a 2750 lb car.
alan
Old 07-29-2006 | 08:09 AM
Lemming's Avatar
Lemming
38-39 hot all around on 225's. Car weighs around 2600 with me in it.
Old 07-29-2006 | 08:46 AM
JET951's Avatar
JET951
funny enough i have used a few sets now and i get the best grip at 32. thats with 255 and 275
Old 07-29-2006 | 11:57 AM
M758's Avatar
M758
38-40 hot on my spec car.
Old 07-29-2006 | 08:54 PM
JET951's Avatar
JET951
i am talking 32 psi. whats that in lbs
Old 07-29-2006 | 08:58 PM
420WHP944's Avatar
420WHP944
It's still 32 lbs per square inch.
Old 07-30-2006 | 02:23 AM
mjensen's Avatar
mjensen
I run RA1's, 245/46/16 at all 4's. I look for 40psi hot, I usually run with one pound less in the rear, except for last weekend where I was at an unframiliar track and had to make a "adjustment" for understeer. I went 2psi higher in the rear and it helped. Talking to tire guys their advise is 40-43psi on our car(3,000lb) and 25-30 heat cycles for competition, not practice. I have found this to be true, other racers can run forever on a set, but mine seem to loose grip around 30...
Old 07-30-2006 | 06:00 AM
JET951's Avatar
JET951
good just making sure
Old 07-30-2006 | 10:35 AM
Skip Wolfe's Avatar
Skip Wolfe
39 front all around. I have founf that you if you are off on your cold pressures and you hot makes it over 40 the grip goes away very quickly. I have been to 41-42 and the car is all over the place. Did you get them shaved?
Old 07-30-2006 | 10:52 AM
shiners780's Avatar
shiners780
Thanks for all the input guys, excellent feedback, I appreciate that.
Skip -- I didn't get them shaved, as I needed to get them in quickly and their shaved tires would have taken an additional 5-7 days to deliver. So when you're kicking my a** on Friday at Nelson's, it's because my tires blocks are all squirmy due to the full tread. That's my story and I'm sticking to it.
Old 07-30-2006 | 10:26 PM
robinsonracing's Avatar
robinsonracing
I agree with Skip, 39-40+ psi and all hell breaks loose. (shaved)
Brian
Quick Reply: RA1 hot pressure on 944/951
