Which paint to use for centercap Crest?
i just sprayed my phonedials bright silver and want to paint the centercaps. i was gonna go get some testors model paint and then have the body clear over that. is that the correct way, just thought i would check here first. thnx, greg
Set to Full-Auto
I used model paint to do my centercaps a few years ago - then clearcoated them with a rattle can. The clear eventually turned yellowish with the model paint, but not the rest of the wheel. I would say use Testors clear on top of the Testors color otherwise you will end up with yellow tinted caps.
I use Testors 1144 gold, 1147 black and 1103 red to paint them. Since Testors is an enamel, you should use an enamel clearcoat. Also, I only paint the recessed areas to reduce degradation from road debris. They have been on my 928 for 4+ years and still look good. BTW I polish them before painting.
Dennis
Dennis
Jane Bond 007
I went to autozone and got touchup paint. No clearcoat to follow and they still look great 3 yrs later. The bottles even have they're own brushes!
I did mine last year and followed advice from guys here,I sprayed the caps with dupi-color bright silver then I took Painters markers I bought at walmart colored the crest gold followed by black then ren and then I clear coated it.
OK, Here they are. i had the body shop spray with a bright silver(no particular silver), then i used testors enamel paint and knocked em out. then sent them back to be cleared again. what do you think?
BEFORE & AFTER
BEFORE & AFTER
