Damn, damn, damn!!!
Damn, damn, damn!!!
Ok so after a month and a half of getting my oil pressure back to normal, I replaced the oil pump yesterday, I set up my timing and start the car and it's barely running, really felt bad, so I go and recheck the timing. Spot on, so I check everything else that got dismantled with the oil pressure problem and I I find a pin hole leak in the rubber fuel line to the fuel rail. Crap is it ever going to end?!!
So, is it possible to repair the rubber line or do I have to buy a whole new one from the rail to the fuel filter?
Oh I so wanted to go driving today.
Thanks,
Thanks,
you can cut the crimped part off of the ends of the lines, pull the rubber off the fuel line and the rail exposing a big farrel. Get some new high pressure fuel line the same size and use good clamps at each end- worked on my 924s and still have had no problems for some time.
