Need connector for speed sender
I have a 85 951 trans in my early car. I need the electrical connector to the seed sender that is mounted in the transmission so I can properly hook it up to an electronic speedometer.
Anybody have one they want to sell me?
I'd like to have a working speedometer to drive to 944fest!
Originally Posted by Bob Ward
thanks theedge but I do not see anything that will work??
no 3 connector plugs or small enough female blade terminals!
Or from KayJayCo you can get "AMP 3 Wire Bare Female Housing", AMP Female Terminal (say 5 of those, extras is good) and "AMP Wire Seal" (5 of those too, extras again) and youll be set.
Either will work, theyre the same. Those connectors are the better versions of whats on there now. No stupid little C-Clip and better weather seal, so you dont need that rubber boot, just some heatshrink to form a strain relief. Or a rubber boot for the same
YIKES!!
$25 for a new connector!
The TPS and AFM connector shells are even more than that
