Throttle Cam????
Old 07-07-2006, 12:13 PM
Spec4racing
Spec4racing's Avatar
Default Throttle Cam????
anyone ever installed an aftermarket throttle cam in there 944??? not sure what it does. any hints??
-Spec4Racing
Old 07-07-2006, 12:20 PM
mavfan
mavfan's Avatar
there is a bunch of information on this here on the forums, basically it does not increase horse power, but it does make the throttle more 1 to 1. your old one has an arm which inhibits it. easier reving, and just a better feel IMO. i installed it on both my cars and the 944 REALLY responded to it, the 924S not so much. an all round good upgrade for the $
Old 07-07-2006, 12:27 PM
Phi1720
Phi1720's Avatar
-Spec
Just posted this on your other thread. Just thought I'd copy/paste since it is more relivent here...
I've got a throttle cam from Weltmiester. It basically takes all the cushion out of the accelerator so the car feels a bit snappier. The long arm on the stock cam makes the throttle pretty soft for the 1st 60% or so & then opens the throttle body full tilt when you depress the peddle past that. The Weltmiester unit is just a circle with no arm so it opens the throttle body at smaller incriments of depression on the accelerator.
For my money, it was a good purchase. The car feels a bit zippier even tho there wasn't really any HP gain. $25 bucks is worth the extra response.
Hope this helps
_______________________
-Scott
85.5 944
96 Mazda Miata
Old 07-07-2006, 12:35 PM
Spec4racing
just what i was lookin for. thanks champions
-Spec4Racing
Old 07-07-2006, 12:39 PM
phil74501
phil74501's Avatar
Would one of those work on an automatic? I nephew drove mine once and said the thought the throttle felt stiff. He's into ricers, but knows his cars. Just wondering if it will work on mine.
Old 07-07-2006, 12:51 PM
35thSLP
35thSLP's Avatar
should work on an automatic NA just fine.
Phi1720
Phi1720's Avatar
http://www.performanceproducts.com/p...e+Response+Cam
Sorry Phil, Manual cars only.
No turbos either. Only fits 944 n/a manual trans
_______________
-Scott
85.5 944
96 Mazda Miata
Old 07-07-2006, 12:53 PM
xsboost90
xsboost90's Avatar
would work on auto and like wise. You may want to make sure you have enough adjustment though to take up the slack on the cables though since w/o the cam youll need less cable.
I took my stock throttle cam and just lopped the piece sticking out off making it round. Took about five minutes and was free!
Old 07-07-2006, 12:57 PM
phil74501
phil74501's Avatar
I think my cable is a little loose, slackwise. Least it seems to be too me. But then I don't know what it's supposed to feel like.
Old 07-07-2006, 01:12 PM
Fishey
Fishey's Avatar
just cut the arm off the factory one for free
Old 07-07-2006, 02:06 PM
Tom
Tom's Avatar
Other than perhaps the angle of your ankle at a particular RPM the advantage of the throttle cam is that it makes it easier to blip the throttle when up and downshifting. This is irrelevant for automatics. Also check and see. The reason there is no cam for 16v cars is that the stock cam is round already, I don't know if that is the case with automatics. There may also be technical reasons not to install on automatics such as the transmission may not respond as quickly.
Old 07-07-2006, 03:28 PM
Uranium-235
Uranium-235's Avatar
I put one on my car, then removed it after about two months. I didn't like the change in throttle response. If you want it, its $10 + shipping.
Old 07-07-2006, 03:53 PM
Campeck
Campeck Rulez
Campeck's Avatar
wow. someone didnt like it? weird
Old 07-08-2006, 11:15 PM
mavfan
mavfan's Avatar
well ya, as i said b4, my 924S didn't respond or feel any different with it, but with my 944 it was like night and day. i dont get it...
Old 07-08-2006, 11:17 PM
xsboost90
xsboost90's Avatar
i cut the one on my gf's 924s down and it made the same difference as w/ the 2.7. Could be an altitude thing.
Quick Reply: Throttle Cam????
