Alternator removal help !
Im trying (yeah trying) to removing the alternator in my 84 944 and Im having one heck of a time getting to the bottom bolt any suggestions ?
The bottom bolt of the alternator has a backing nut on it as well, so you'll need to use two wrenches or a socket and a wrench to get it off.
Obviously you can remove the bolt with the alternator belt on, but you have to do it 1/4 turns at a time. Be patient, you'll get it.
Check www.clarks-garage.com , he has all the tools listed.
All the sizes are 8, 10, 12, 13, 15, 17, 19, and bigger. I can't think of any 7mm, 9mm, 11mm or 14mm or 16mm nuts on the car.
There's a bunch of 14mm bolts in the engine bay I believe... I lost my 14mm socket and i got frustrated numerous times when I needed it, so that's how i remember.
14mm? Where would that be on an early car? Or any of these cars, for that matter. I haven't run across one yet in any of my earlies. You must have un-original stuff in there........if thats even possible.
