Rod knock - When do you hear it?
Just for giggles, let's suppose an engine was developing rod bearing issues. When would you start to be able to tell? Sparkly oil drains out of the pan during an oil change? Distinct sound while engine is running? And when would you hear the sound, all the time, under load, idling, at shut down?
Just wondering
Just wondering
I had an old Pontiac with bad bearings - you'd hear it at idle, then it would go away as the engine speed increased. Probably depends on the extent of the damage.
Always always? I know what it sounds like, but I have only heard it on motors that had it pretty bad. I was wondering if there is a particular instance when it would occur in the the early stages.
Rod knocks get louder as the car is warmed up due to lower oil viscosity at higher temperatures. Higher revs should make the knock sound louder especially under low RPM high loads.
Wax On, Wax Off
When mine went, it could be heard at idle, sounded like a bad lifter...but a little louder... then, on the freeway, it got louder... then it finally ate itself, and was VERY loud at idle... ya know the sound of a bad engine in the movies, with the knocking every so often? yeah... it sounds like that...
and my oil wasn't sparkly, it was chunky...
