Oil leaking on exhaust pipe
ive found that my 944 is leaking oil onto the y-pipe, which of course is making smoke and a nasty smell. right now i dont have the means to get it up in the air and have a look underneath (a buddy is borrowing my jack stands) but im not confident that even when i do i will recognize the problem. judging by the picture, can anyone tell me where this leak is coming from? when i get underneath (possibly tonight) i will take some more pictures. please someone tell me its easy to fix, im strapped for cash!!!!
![](http://i16.photobucket.com/albums/b4/funcheon5488/DSC01463.jpg)
Defending the Border
Rest In Peace
Rest In Peace
Befor the jackstands, take the car over to the car wash and blast the engine off, trying to find a leak on a dirty engine is much harder. Not to mention having to work on it.
Based on that location, i would check the rear cam tower seal..it is held on by the same bracket which has the ring for the rear engine hoist point. Its a cork gasket, $1.50 at the dealer (of all places) and is not tottally uncommon to leak. Also relativley easy to change, only 3 bolts.
That's a pretty good sized leak. Judging from the position of the oil slick toward the bottom of the picture, I would be more inclined to guess rear balance shaft seal. Cam box gasket is the next most likely. This is easy to check -- just run your finger around the base of the cam tower. They usually start to leak toward the back of the motor first (i.e., near cylinder 3 or 4).
