Sloppy 944 shifting
I'm sorry to make another thread about this one, but I checked up on old threads, and didnt find the info I needed. The shifter in my 88 944 has crazy amounts of slop in it. Side to side in any gear it probably has 1.5-2 inches of play. It shifts fine, except sometimes 5th and Reverse are a tad vague. I heard that there's a fairly simple fix to the problem, by making sure a bolt is tightened. A few people loaded pictures of the bolt in question, but for some reason it just won't load on my computer. Could someone help me out?
1 Post
There is a pin/stud (about 10mm in diameter) sticking out of the shift lever, which connects to the rod that goes to the transmission. This pin is probably worn out, can be replaced with a 10mm bolt (tapped only at the end). This requires some basic hand tools, including a tap. Of course you can buy a new one.
Drewsifer...I hear 'ya fella. That thread had to do with the bolt near the transaxel..or on top of it. I could not see the pic either. I also would love to see the pics again.
Hey Man
http://www.dietersmotorsports.com/tech/tech-july-03.htm
Originally Posted by KuHL 951
Yours sounds more like the shift lever pin, especially the side to side slop. IMO this is still the best permanent fix for a bad shift tube and pin and eleiminates all metal-to-metal contact using replaceable nylon bushings.. I've done several now and my 86 still has less than 1/4" of sideplay after 2 years. Do the rear bolt first and if it's still loose take a look at the link.
A new shifter assembly is only like $75 and takes maybe 30 min. to install, if that.
There's no harm in delaying the repair as long as you're a bit careful about shifting. Take your time, don't force it, etc....
Hey Man
While thats something I probably should do, right now I just dont have time. I hate to sound like I'm taking the cheap way out, but is there a quicker fix for this? Would I be hurting anything if I dont take care of it right away?
thanks
R
1 Post
Originally Posted by 944 Robin
can you expand on this repair? does the bolt replace the pin and clip on the shift lever?
thanks
R
thanks
R
But after reading that a new shifter costs $39, I'm not sure if it's worth doing this fix with a bolt.
In either case, you'll thank yourself for doing it, as the shifting is so much better.
Hey Man
When and if you do the shift lever, 9 times out of 10 the shift tube needs to be returned to round and either resleeved or requires the plastic bushings in my link above. I tried just the lever replacement on my 86 and still had a full 1-1/2" of slop due to shift tube wear until I took it one step further.
Steve & Stan, both excellent plans. i am going to do some hardware hunting at work. several of our project have nice shoulder bolts. but the price of a new lever is worth going that route too. may just do both,always nice to have a spare!
Robin
Robin
