951 starter caution
![Exclamation](https://rennlist.com/forums/images/icons/icon4.gif)
I recently purchased a starter for my 86 951. It didn't have the correct bolts/studs for attaching the heat shield, it cautioned me as I have read of people getting starters with the wrong rotation. After pulling my starter out I noticed I could rotate the gear in only one direction, the replacement starter gear would only rotate in the opposite direction. With jumper cables I connected each to the battery and discovered I had purchased a starter with the wrong rotation. Luckily I didn't install and try to start my engine, I have visions of timing belt jumping teeth and bent valves, etc...
Are all 944/951 starters the same ???
Hey Man
Originally Posted by Rip It
... Are all 944/951 starters the same ???
![](http://forums.rennlist.com/upload/starters.jpgsmall_copy2.jpg)
The last three digits of the part number on the one I orginally purchased was 109.
The last three of my small body type is 115. I just received the correct starter in exchange.
Hey Man
If you had a starter that turned backwards you didn't get one for the 944 series or it was made built wrong. Wasn't some of the Golf FWD cars the ones that mounted facing the opposite direction but looked the same as a 944?
1 Post
Originally Posted by KuHL 951
There are small body and large body starters. Many shops selling starters list them both as the same part number and they fit both 944 and 951. The 951 used the smaller body and a heat shield to prevent heat soak. I have a large body starter on both of mine. I ended up making my own heat shield for the 951 from a front brake cooling deflector...sort of McGuyver but it works OK.
Mine does not have one and maybe I could shamelessly copy what you've done if I saw a picture of your installation...
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Hey Man
Originally Posted by 951Porschiste
Any pics of that heat shield in place?
Mine does not have one and maybe I could shamelessly copy what you've done if I saw a picture of your installation...![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
