So smoke starts pouring out from under my hood...
Unbannable
My GF and I were driving the 944 back from a short happy hour with the AC on (the Miata is off the road getting some new gauges
) and I notice that the AC stops blowing cold. I know it needs a recharging but that was still "not right". A minute or two later, while sitting at a light, white smoke starts pouring out from under the hood!
Eep.![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
I quickly pull over, grab the fire extinguisher and we both exit the car. I go to the front to analyze the situation and see that it's still smoking, but not billowing like a massive fire. I also feel no extra heat. I pop the hood (but don't open it) and that doesn't release any extra smoke.
Deciding that there probably isn't a massive fire, I feel that the hood release is cool and carefully open it, prepared to jump back or blast with the extinguisher. When open, I find that the smoke is coming from the AC compressor. I'm not exactly sure of the source, but I see that there is a plastic harness-looking thing (I couldn't say for certain) that was right on top of it and molten. I also hear lots of little crackling.
After letting it cool I try and remove the molten stuff but it just melts in the pliers. I turn off the AC and continue driving, making it the rest of the way back with no other issues.
I think I shorted out a harness somewhere. There was no belt squeal during all of this and the belts are fine, so I'm pretty sure it's not a siezed compressor. I'll have to investigate this further. It sucks that I have essentially lost AC in that car, but it's not too big a deal since I don't use it all that often anyway.
But still... that scared the **** out of me...![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
Thoughts?
BB.
P.S.~ I need a beer...
Eep.
Thoughts?
BB.
Unbannable
It seems to be a shorted wiring harness. I'll get pictures in a couple days when I can dig in there. It seems like an odd place for a harness to be (right next to the pully) so I don't know if it came loose and wore itself down or what...? ![Confused](https://rennlist.com/forums/images/smilies/confused.gif)
BB.
BB.
Unbannable
The belts look good, but no idea on the clutch. I'll know more when I dig in to it. But at least I can drive the car in the meantime with no problems. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I had a similar incident years ago with my Scirocco when the alternator wiring harness went. Not as much smoke, but no fuses went then, either.
I attribute it to the glorious german wiring.![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
BB.
Originally Posted by cjeckert
Hmm and the fuse didnt blow? thats kinda odd
BB.
Same thing happened to me. My AC Compressor seized and died. The smoke was from the belt. Turned the AC off and drove the 70 miles home, no problems, but arrived hot and sticky. Bit the bullet and put on a new Porsche AC compressor...
Unbannable
Well, I'll dig into it sometime next week and see what I come up with. At that point, I'll either contact you for the harness or cry for a new compressor...
BB.
BB.
BB.
BB.
Unbannable
Hrm...
I just took a look at the belt. I didn't get too far before I noticed the 1/4" split from one end. Not good.
I then turned on the car and went to observe. While wearing eye protection, I had my rooomate turn on the AC. I couldn't get a good look at the compressor but the engine slowed substantially (more than the usual AC slowdown) and I heard a groaning that went away as soon as he turned off the AC. He turned it back on and the engine slowed again (no groaning this time).
So, yeah, methinks it's the compressor.![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
Granted, I can ignore this during the summer, for the most part. If it's that hot Tracey can drive. Unfortunately, this might make my job interviews a little more annoying but I'll play that one by ear. If nothing else I'll go in shorts and change into the suit when I get there. Hopefully, they'll be impressed by my resourcefulness...![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
BB.
BB.
The compressor can seize and the rubber damper of the a/c clutch will break. The pulley will turn after the rubber damper of the a/c clutch breaks off and the friction is what creates all the smoke and noise. I have seen that happen twice and changing the compressor/recharge the system will fix your problem.
Unbannable
I shudder to think what it'll cost to recharge the system. But then, I'll have to look into the cost of various o-rings and the reciever/drier because this might be a good opportunity to upgrade to R134a.
BB.
BB.
