Issues using "cooler" thermo fan switch?
Location: Brisbane, Australia (Formerly: Sunnyvale, CA)
Hi all,
The thermo fan switch on my S2 has failed, so I need to get a replacement. The standard switches are 92/102 degrees C, but I notice there is a "cooler" version that switches at 82/92 degrees C.
What issues do I have to consider, in choosing one over the other, if any? What's the rationale for selling the "cooler" switches in the first place? Any disadvantages I should know about to having the fans coming on at lower coolant temps?
Thanks for any advice.
-Mark
-Mark
Originally Posted by bearone
both the water pump and switch need to be low temp.
87951
87951
-Mark
If your cooling system is less than optimal, a lower temp switch can cause problems in that the fans may run a lot longer than normal since the low temperature cut off is never reached during operation. This would also keep the fans on longer when the car is shut off.
How do you like it in Brisbane Mark? I've been there several times on business and really enjoyed it.
Wahler and Thomson/Behr make switches that activate the fans at 120*F. Like the others have mentioned- make sure the thermostat matches accordingly. Your car will run cool as a Cucumber.
Zach
Zach
Mark, the reason you need to lower your therostat if you lower you fan switch is that if the fan comes one, but the thermostat isn't open, it doesn't help to cool, because the coolant isn't circulating. I'm thinking of puting in the lower temp thermostat and switch, too.
![Smile](https://rennlist.com/forums/images/icons/icon7.gif)
Originally Posted by Mark944na86
You mean the thermostat in the waterpump? Why would this have to be lower temp? Once the engine reaches normal running temp, this is always open anyway... the only thing the thermo fan switch would do is to keep the fans running longer over the radiator... so don't understand the reasoning here.
-Mark
-Mark
depends on the value of the thermostat as to where the temp will run, and the switch picks up the increase in temp and turns the fans on so both need to be low or hi.
it would seem that if you had a low temp thermostat but hi temp switch, the fans would come on later, at the higher value, which gets you closer to the 3rd line.
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
87951
I also run the lower temp thermostat. Car sits right on the first mark when driving. On really hot days in traffic, it never goes above the 9 o'clock mark.
UAE Rennlist Ambassador
The OEM from Porsche is rated at 91/105C
Cooler versions run in the 80C/91C range
Been using the cooler one on my 951 and NA, i have to since the weather here is hot (it was 114F in the shade today).
The hotter the engine runs the more efficient it is. Most modern engines run
220f to 240f. As long as the coolant is not boiling and has a good pressure cap, it is not too hot.
I don't know where you got the info on where modern engines run 220-240F (104C-115C) is incorrect, since the brand new 06 BMW 323i has the high speed fans kick in at 91C.
Come to think of it, the red zone in the 951/944/968 is 115C (240F).....that's NOT good.
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Ceramic engines have been built which use no cooling, or very little. I have run engines to destruction with no coolant and they always run the best right
before they give up. Most American cooling fans are computer controlled to
turn about 240F.
turn about 240F.
