Stupid mistake
Canadian Yankee
Stupid mistake
Well I learned the hard way today want happens when you put jack stands on the jack points of the car and use a scissor jack. Rich Sandor ius right use the front subframe and rear trailing arms to put the jack stands on. I ended up putting a hole through the bottom of the floorpan. I am going to use black silicone to close the whole up, but do you guys tink that I should get it fixed because I am worried that over time it will open up for fromthe flexing of the car. Here is a pic.
Brandon
Brandon
WTF... Then why did Porsche give us a designated jacking point if you can't jack from there? I just used the trailing arm and control arm by habit, since that's what I used before I found out about the jacking points, and they work well. I'm glad I never tried it though!
Originally Posted by xsboost90
when you get to KY- come up to my lemans party and i'll get the welder out, tack it closed and undercoat it- 10 minutes tops.
Canadian Yankee
Thanks Dan, by chance do you have a mig welder someone told me it needs to be be welded shut. June 17th sounds like fun, anybody else for south KY/Northern TN, going up to Cinci for the party? Oh yeah how far is it to Cinci from my place in Bowling Green?
Brandon
Brandon
