Missing washers- should this make me mad? Plus a real question..
When I first got my car I wasn't prepared to work on it and spent a lot of money getting oil leaks fixed, one of which was at the cover at the rear of the cam tower (new gasket installed.) Last night I removed the rear engine lifting bracket for re-plating, and the bolts were barely tight. I also found that they DIDN'T EVEN BOTHER TO PUT THE WASHERS BACK. I remember that they also complained about how hard the bolts were to get to. I'm guessing it wouldn't have been long before I had another leak there. This is a shop that specializes in these cars.
The parts manual lists these as spring washers. I assume they function as lock washers. Is that right? It seems to me that over-tightening the screws would break the cover.
Should I order original spring washers or just use lock washers? Loctite? Some experienced advice would be appreciated.
yes, they function like a lock washer.
you can get a metric spring washer like that at your local hardware store, they just look like they have a little wobble in them. i replaced my 3 with SS bolts and washers i found them at ACE where i work no problem at all.
you would have to tighten the snot out of it to break that aluminum cover, but i wouldnt worry about that, i dont think they are torqued over 15-20lbs to begin with
