DAMMIT! Massive Oil Leak
So I just finished putting the car back together after replacing the HG.
Started up, ran great! BUT (there's always a but) it is puking oil from the CAM TOWER. DAMMIT DAMMIT DAMMIT.
Stupid question after the fact. SHould I have used any kind of gasket prep before putting the gasket in place?
Thanks -- Pissed off in FLA.
Originally Posted by PeteL
It's the sides. The surfaces were clean, I did not use any sealant.
Can't get a new gasket until Monday. Any chance of using this one again?? Using sealant this time?
i think the gasket on these is specifically for keeping oil out, not for anything else. i'd say yeah, but i'm retarded, so i'd say be safe and ask someone else.
but my "educated" guess is yes.
Make sure it's cleaned up really well and not pitted. I never used gasket sealant on that part before and it has never leaked on more then one car. Good cleaning and inspection is the keep part. Maybe you didn't tighten down the bolts enough. Good luck.
i think the bolts are only 14lbs of torque, but make sure you put in all 35 or em, lol.
also there is a the cam main seal up there and on in the rear, or is it actually coming out where the cam tower and head meet?
