will this oil pan fit ?
not sure on the part number my PET is at home. Does it have a plastic baffle inside of it that bolts in? If so that should be the correct one for your late car. The early ones should fit also BUT they dont have the baffle that helps w/ oil starvation. If you have your pan off, get a late pan and have the lindsey oil pan baffle kit welded in at a local shop, verymuch worth it in the long run.
Thanks xboost90,it does have the plastic baffle,and i am going to do the baffle weld in upgrade.i just was not sure there was 2 different type baffles for pre and post 85/2
