Anyone have a door panel off that can check something for me...???
...my driver door- after it stops at the midpoint, it pops really loudly- the piece that hooks into the door about midway & catches it to keep it from opening too far is what I'm looking at- it mounts to the forward frame of the car w/two star-shaped type bolts- when the door goes past the midpoint, it slips slightly- is this a specially sized tool or something? What do I need to tighten this? It's not that loose, but, on the other side- if you look at it from the backside, through the holes, you will see two bolts that stick out- ok, this side is pretty loose- it's much more noticeable when moving the door past the middle stop- well, there are no nuts or anything on the ends of those bolts- should there be, or, is it attached inside the little metal box somehow? I'm assuming it's not supposed to be loose? Last question- t he driver side has a stop about midway- I'm not noticing one on the passenger side- should there be one?
thanks a lot,
thanks a lot,
Thanks a lot Mike... I'm not really sure if a pic would work, but if you don't mind trying... it's just such a small piece that it might be tough to show up... I'm sending you a PM w/my e-mail addy...
thanks
thanks
You need a 6mm Triple Square bit or a Star bit size T-30 will work in a pinch, I can loan you one or they have them at the parts store.
Both doors should have a middle stop, my drivers side does not and it needs replacing.
thanks a lot guys....
Shiners- does the thing move at all inside the door when you open it all the way out?
David- that's funny... my passenger side feels fine & is smooth & quiet, etc... it just goes all the way open nice & smoothly... hmmmm... maybe I'll replace both then- getting into stereo stuff & plan to cover the door w/dyna-mat type stuff... I want it to all be done before I seal it up.... Ive got at least a week before I'd even have the new parts here... was just thinking that tightening it up might help a little, but probably not... I'll go price the tools & see what I come up with...
thanks again everyone...
