Introduction - Brian 944
Old Mar 16, 2006 | 09:33 PM
  #76
Brian 944's Avatar
Brian 944
Originally Posted by 9444Alexis
Quick question: how will that engine bay lining stand up to steam cleaning if you have to do that? I always figured the engine bay kinda had to be engine enamel.........
Soap, Sponge, Rince.
Steam Cleaning is for Trucks.
My cars get detailed, not pressure washed.
The steam would strip that **** off.
Old Apr 6, 2006 | 11:50 PM
  #77
Brian 944's Avatar
Brian 944
06 April 2006
Update.
Motor going in this weekend...
Interior Rebuilt....
Both doors open and the trunk works now..
Old Apr 7, 2006 | 01:04 AM
  #78
jabbadeznuts's Avatar
jabbadeznuts
one word.... WOW
Old Apr 7, 2006 | 01:27 AM
  #79
Blue S2's Avatar
Blue S2
Yeah, this is pretty awesome! Impressive work!
Old Apr 7, 2006 | 01:38 AM
  #80
eohrnberger's Avatar
eohrnberger
Cool. Can't wait to see it all together and running. Bet it'll be a blast!
Old Apr 8, 2006 | 10:59 PM
  #81
jeff_944's Avatar
jeff_944
WOW!! I haven't been on here in a little bit and now I see this! I can't believe that there is that nice a 944 in New Brunswick. I always see all these beautiful 944's from down south but never up here. If you ever need any help with the car shoot me a pm, I am over in N.B quite often and would love to take a look at it.
Old Apr 8, 2006 | 11:18 PM
  #82
yellowline's Avatar
yellowline
Under the Radar
At some point, this thread will be worthless without video. Nice!
Old Apr 9, 2006 | 07:27 AM
  #83
Brian 944's Avatar
Brian 944
Thanks, I have the motor back in now and I need to do the final interior trim on the B-Panel then put the rear 1/4 Glass in today. Might get some other stuff in as well.
If you are in the Oromocto Base Gagetown area let me know before you come down.
Old Apr 9, 2006 | 07:39 AM
  #84
Brian 944's Avatar
Brian 944
April 08 2006
Holy Crap,
My 10 Min job turned into a 3 Hour PITA.
Didn't really clean off the toothed driveshaft in the torque tube as well as I should have and the clutch didn't go on the shaft without alot of "Help"
Basically, it's all in there now and Pete and I tested to make sure that it's all working fine.
1st gear and I manually rotated the crank, the car moved a bit
4th gear and I manually rotated the crank, the car moved a lot.
PERFECT!
Today, I'm going to start to put the parts on like a big German Lego set.
Peace!
Old Apr 9, 2006 | 10:22 AM
  #85
xsboost90's Avatar
xsboost90
that things awsome. I would like to see how it runs w/ the supercharged setup you have, i could be wanting something like that.
Old Apr 9, 2006 | 11:08 AM
  #86
apen749's Avatar
apen749
Brian,
You've accomplished a lot with this car. It's looks great. Keep the informative posting going. I'm very interested in the supercharger. You just made your own set up verses buying a kit. I'm wanting to add to my car but I really haven't seen much talk on the board with someone actually getting one.
Thanks, Lee
Old Apr 9, 2006 | 11:21 AM
  #87
Chris_924s's Avatar
Chris_924s
Nerd Herder
Amazing Work Brian. Talk about a "labor of love".
I'm gald you are on OUR side (Porsche , that is! )
Have you thought about 944 Fest?? We would LOVE to see this when it's finished.
Old Apr 9, 2006 | 06:57 PM
  #88
Brian 944's Avatar
Brian 944
Bled the Clutch Master and to test the clutch I placed the car in reverse with two ramps behind the car.
I manually moved the crank with Spark plugs removed with a 24 mm ratchet on the crank bolt.
Car went up ramps perfect, then with the car still in gear I pushed in the clutch and the car slid off the ramps like a charm.
So, The 944S2 Clutch is totally compatible with an 86 844 NA 2.5L
Old Apr 11, 2006 | 08:58 PM
  #89
Brian 944's Avatar
Brian 944
April 11 06
Updated picture of the Weekends work.
There are some Misc bolts holding stuff together that are the wrong length on the Fuelrail etc, and most of the sensors have to be hooded in but the hard part is done.
Old Apr 11, 2006 | 09:17 PM
  #90
kennycoulter's Avatar
kennycoulter
Originally Posted by Brian 944
Does the Car have a MAP or MAF?
i tried to also quote neondrivers post also...
if you do searches on turboford.org, you will find info on making the "afm" work as a blow through design. they call it a vam though, as in vane airflow meter. even on the ford turbo cars, the meter is still in front of the turbo, so air is always drawn through it instead of experiencing pressure AND suction.
