is mixing oil types okay?
I just put in 5q of Mobil 1 10w40 regular dyno oil and ran out
The only thing I could find for the last 2q is some Mobil 1 5000 10w40 dyno. Its for 5000 mile changes instead of the regular stuff.
Would it better to put the Mobil 5000 (silver bottle) or some Mobil 10w30 like the 10w40 (blue bottle junk)?
Thanks!
Thanks!
Mexican Ambassador
better to stay with the synth/dino mix insted of mixing w-40 and w-30.
it just dillutes the effect of the synth oil...and makes dino oil better? who knows. oil experts will tell you this way and that way, but fill up with the same grade even if it's not the same (dino or synth), and just fix it when you get to the next oil change.
from what i know......ok, that's too much tech for my brain, back to OT
edit- ride your bicycle to the store and buy a case of mobil 1 and an oil filter and do the oil change.
Mexican Ambassador
Originally Posted by Operator
the mobil 5000 isnt synth
its just .. some weird different dyno blend of 10w40 than the bluebottle stuff...
ok, so if it's a synth/dino blend, then what's the problem?
either way, 10W-40 and 10W-40 mix better than 10W-40 and 10W-30.
the mobil 1 website says 5000 isnt synth. so if the oil you're starting out with isnt synth, what's the problem?
as long as they're the same grade/rating/whatever oil's measured in, it's ok.
Administrator - "Tyson"
Mixing corn oil and peanut oil may not be the best idea for your Porsche.
Originally Posted by 951Obsession
what about love oil?
Mexican Ambassador
Originally Posted by Hacker-Pschorr
If you have the stamina to come up with 5 quarts, I say give it a try. If this involves you and a bunch of your buddies, spare us the details.
i think mixing love oil with mobil 1 is bad, it always makes you think you've blown a headgasket.
Mixing is fine. Blended mixes have been sold for years (dino and synth). My families Dodge Caravan has been getting mixed grades for years, it burns less oil than most of its brethren. It usually gets some random mix of 10W40 and 20W50. Its never gotten synth or preblended stuff before, thats too espensive for an 88 Caravan
dang... you guys will mix anything and dump it into your Porsches.. gross
thanks for the advice. ill finish it with the 10w40 5000 junk. cant hurt!
