How to remove windshield washer nozzles from hood...
Wax On, Wax Off
alrighty. mine are clogged to hell, and I'm gonna attempt to clear em without having to replace em. i found underhood the wires for the heater, and the hoses, and where they connect, I just have NO idea how to remove the assembly from the car....
Thanks guys.
Thanks guys.
Location: Albany, CA: celebrating 100 years of independence from Berkeley, CA
IIRC, if it's anything like my '87 944, there's a little clip (I think on the side facing windshield) that you need to compress and the little bugger can be pressed up and out.
Wax On, Wax Off
Well that was easy... no clip up front, but you slide the nozzle towards the back of the car, then pull it out... wow. ANYWAY, I can now spray the magnesium chloride from my windshield and see where I'm going again! yay!
I s'pose I should try that - I just replaced all the "T" and "L" check valves and even the hoses - still crappy performance. I tried blowing 'em out with compressed air but maybe removal and hand-cleaning would work better.
Budding Photographer
Hmmm - I'll have to try that. I always stay clear of them when waxing so as to not get wax build up on them, but unfortunately by not getting wax on the paint there you can tell a difference in the depth of the color. I've always wonder'd how to do that, just never looked into it to find the answer.
Thanks Fellas
Thanks Fellas
Wax On, Wax Off
Cory, you can cover them with masking tape while waxing to prevent that. works really well. make sure it sticks on there good first, otherwise, it'll get ripped off and go under the buffer, and ugly words will be said by the otherwise mild-mannered Cory...
