Car shaking around 60mph
83 944 w/ manual rack. At about 60mph the steering wheel shakes and vibrates (wheel shimmy) pretty bad.. WHat are the probable causes of this? What should I check.
Also it does the same thing while braking. I have brand new rotors and I doubt they could be warped.
Banned Pirate Queen
Wheel out of balance would be my first thought......the cheapest fix too. I am guessing this from the fact that the shake doesn't happen until 60ish. Might have thrown a weight somewhere.......
Wax On, Wax Off
yeah, I'd say out of balance, or a bad wheel bearing... jack up the front of the car, grab the top and bottom of the wheel, and rock it back and forth... if there's a lot of play, adjust wheel bearings.
The 1983 944 has no ABS braking. This means numerous flat spots exist on your pre-1987 944, because even ONE panic stop will take your tires out-of-the-round, my friend. Make sure there is no oddball mix/match brand tires too.
Zach
Zach
Zach
Zach
yeah no mix match tires. no flat spots. thanks.
Bad Camber/Caster settings is another possibility. Looking from above the car- one wheel may be slightly forward of the other, and not evenly parallel. Bent struts and overlooked fender-bender repairs can give your car a world of unpleasant ride issues. Does the shimmy feel like an oscillation transmitted throught the steering wheel? Again- bent control arms, balljoints and tie rods factor another variable to the troubleshooting effort. Even tired front shox sloshing inside stiff springs will give a nasty THUD! jarring your senses when going over potholes, speedbumps, or finished construction, known as Uneven Pavement Surface, with a fresh asphalt pebble blasting.
Zach
Zach
Normal ****!
Starts about 95km/h, ends at 110km/hr.
I am led to believe that this is an inherrant trait of our old n/a's.
I had alignments, balances, and new tyres and shocks and steering joints done. Still there!
Drive under or over the problem speed and it's not a problem!
Yagottaluvaporsche!
Yagottaluvaporsche!
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
