Spark plug wires, cap and rotor. *FINALLY DONE*(pics)
Old 11-08-2005, 10:16 PM
Antonio951
Antonio951's Avatar
Default Spark plug wires, cap and rotor. *FINALLY DONE*(pics)
Decided to replace the 20 year old wires, cap and rotor. I don't believe its ever been done before on the car. Im not the best mechanic in the world and the most "mechanical" work i have ever done to the car by my self is to install hood shocks, air filter and spark plugs
The only part im stuck at is the rotor, don't know how to get it of. I assume the little nut in the pic is what i need to remove in order to get it of.
Heres the pics of the old wires and cap and some pics i took this past weekend drive.
If anyone has any sudgestions please let me know.
Thanks in advance
Antonio
Old 11-08-2005, 10:22 PM
Techno Duck
Techno Duck's Avatar
The rotor is held on by a hex bolt. Look along the rounded portion of the rotor and you will see what im talking about. I dont remember the exact size of the allen key you need, but i seem to remember it being 3mm, maybe 4mm.
Just make sure you thread lock the bolt when you put it back in.
Old 11-08-2005, 10:35 PM
87944turbo
87944turbo's Avatar
Nice work Antonio. Car looks great as always! I completed the same job several months ago too.
Old 11-08-2005, 11:09 PM
Macfreak007
Macfreak007's Avatar
its so great when you can look at a car like yours, totally stock, and think it is the hottest thing alive, these cars never cease to amaze.
Old 11-09-2005, 12:10 AM
ibkevin
Defending the Border
Rest In Peace
ibkevin's Avatar
Great looking car, great looking engine bay!!
Yeah, pretty amazing--I replaced my 83's cap, rotor, and wires about a year and a half ago--a first time on the car. She's always started.
Old 11-09-2005, 11:53 AM
Antonio951
Antonio951's Avatar
I found the kex bolt and its on the bottom of the shaft. Pretty hard to get to if you look at the pic of the rotor. I was told i can crank the engine so the rotor turns and i would have easier access to the bolt. Is it ok to crank it with the cap/wires of?
Old 11-09-2005, 12:00 PM
Macfreak007
yeah, you can crank it, by hand would probably be really easy.
Techno Duck
I see no problem with doing it, however i would pull the DME relay for safe measure so you dont flood the engine with fuel. As long as your not cranking it for more than a second or two you shouldnt have a problem.
Old 11-09-2005, 01:42 PM
Epic2112
Epic2112's Avatar
Just be carefull with the boots on those wires. The rubber is pretty soft, and it's easy to damage them. I bought a set of those wires for the 951 because the ones I have on my M3 are fantastic. I've already replaced the set I had on the 951 with regular wires.
Old 11-09-2005, 01:43 PM
Antonio951
Antonio951's Avatar
I only need to crank it for maybe a half a sec, just to get the rotor turned a half turn so i can have access to the bolt.
I just didn't know if anything would get damaged cranking the car while the cap and spark plug wires was removed.
Epic2112 thanks for the advice, im being careful while installing the wires.
Old 11-09-2005, 02:01 PM
75ohm
Resistance is Futile
75ohm's Avatar
That is a fine specimen that you have there, Sir!
Old 11-09-2005, 02:11 PM
streckfu's
streckfu's's Avatar
Or just unscrew the hex where it is. It doesn't need to be turned to access it. Besides, it only goes on one way.
Old 11-09-2005, 02:58 PM
Robert D
Robert D's Avatar
Can't he just turn the crankshaft with a breaker bar?
Old 11-09-2005, 03:07 PM
apierce918
Addic
apierce918's Avatar
yes
Old 11-09-2005, 06:06 PM
SoCal Driver
SoCal Driver's Avatar
I'll gladly take all of the stock end connectors.
Quick Reply: Spark plug wires, cap and rotor. *FINALLY DONE*(pics)
