First peice of the NA turbo is here!
#106
Originally Posted by Serge944
The 951 is 8.0:1 and has trouble at over 18 psi over atmospheric.
#107
UAE Rennlist Ambassador
Originally Posted by Skunk Workz
Given the stock cam timing and the stock turbo efficiency in regards to back pressure,no wonder... the cam's a necessity though.
At 19psi, the temp out of the intercooler was over 21 degrees hotter than that of 18psi......talk about efficiency.
#108
Campeck Rulez
The k26 is a dinosaur. Almost every modern turbo is better. Take a look at a garrett t04e with a .63 exhaust A/R and a 50 compressor trim. The efficiency range of that thing is perfect for a 2.5l with modest boost.
But, since you always have money - take a look at the Garrett GT turbos.
As Geo said, 12 psi is murder for your car. You have a 9.7:1 comp ratio!! The 951 is 8.0:1 and has trouble at over 18 psi over atmospheric. You're been reading the turbo books youve been buying, right?
thanks serge. ill try and play around with a to4e's compressor map. jeez. here comes all the math again.
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
Geo. im not going to shoot for 12 first. i know somethign bad woul dhappen if i did that. 8 psi is perfectly reasonable. then after a while push it up psi by psi. again...if the engine breaks, its not the end of the world.
#109
Race fuels
Or make your own..
Formula #1 - Toluene
R+M/2.........114
Cost...........$2.50/gal
Mixtures with 92 Octane Premium
10%...........94.2 Octane
20%...........96.4 Octane
30%...........98.6 Octane
Formula #2 - Xylene
R+M/2.........117
Cost...........$2.75/gal
10%...........94.5 Octane
20%...........97.0 Octane
Regardless of your poison I suggest mix in 4oz of marvel mystery oil with every 1 gallon of additive used. Since both are dangerous to fuellines without MMO.
http://www.rbracing-rsr.com/turbo/Tu...s/td04-15g.gif
15g Turbo would do the job nicely and they are cheap!
#111
You gotta have a plan, and make it close to what you want to do. I wouldn't suggest to build it for 5 psi and maybe work up to 15psi. It will be two totally different setups if you do it right. There's alot of good info here, just listen to it. The head design is lacking, especially for the compression and expected boost. When I was planning out my NA turbo setup, there was no way I would have done it without knock control. By the time I had it all planned to make it into a turbo, it was basicly an over priced 951 motor with NA pistons. I'm not saying don't do it, I'm saying don't do it unless you are going to do it right. I wish I had the money to go 16V, it's probably the best chamber and head design that would bolt onto a 2.5. I may just say screw it and do it anyway, dunno, it'll put me back an extra year. That may be what it takes to do it right istead of being let down first. We'll see. Good luck, I really want you to prove me wrong, I really do. For the budget and the parts being used, shoot for maybe 10 tops, plan for 7-8. BTW, a T-3 Garret from a Turbo Coupe would probably be decent on there. Check out www.turboford.org and see which cars had the bigger AR, I think it was the earlier ones without intercooling.
#112
ealry t-coupes up to 86, and early merkurs up to 86. svo's from 84-86 had the bigger t3 instead of the small ihi. svo's had different a/r ratios on 85.5-86. i think .63. .48 on early? maybe backwards from that. check out www.nato.com or even www.svoca.com>>>>just dont ask them questions. theyre all elitist dicks on there, and wont give you info unless youre restoring an svo.
#113
As several folks have said, modern turbos significant improvements over any 80s turbo. Get the best you can afford. A Garrett GT turbo would rock but they cost as much as most NA 944s are worth!
#114
Originally Posted by Geo
Wow, that would be a trick.
What's next, a perpetual motion machine?
#115
The main component producing backpressure in a 951 is the turbo itself...so headers doesn't do much on backpressure at all. Lag is a combination of factors...especially when you tune it.
Ok...then I better save the cores I have for the really hardcore racing...![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
#116
Originally Posted by 944CS
my point was that the "log" manifold is going to hurt spool time because exhaust gases are going to be fighting to get out of the combustion chamber instead of flowing more freely with a 951 manifold to the turbine wheel
#117
less than 5 psi and once you are moving, yes it does make negative temp...why is it hard to believe that the intercooler is doing its job?
Please explain how this works.
#118
the only way you could use an air to air intercooler (without misters and other cooling aids) to get below ambient would be to have the air expand after the intercooler... effectively turning your air intake into a refrigeration cycle.
#119
Misting units wouldn't lower the temp below ambient unless the fluid used to exchange the heat was cooled below ambient.
Expanding the air at the IC will cool it, but that will reduce the boost, and once you compress it again, the heat will come back. IOW, it doesn't really work.
